LSx and TH350
Old Mar 29, 2012 | 05:34 AM
1970's Avatar
Default LSx and TH350
2004 LM7 stock engine, 1970 Chevelle TH350 stock transmission.
What modifications are needed to engine or transmission?
What starter works?
What fly-wheel works?
What kickdown works?
Old Mar 29, 2012 | 07:22 AM
1bad03snake's Avatar
I just did this swap and i used a 6.0 flex plate/spacer/longer bolts. My converter was drilled for 2 bolt patterns and it lined up perfectly. Im using the stock truck starter. Im not using a kick down so i have no idea about that question
Old Mar 29, 2012 | 11:30 AM
406ci68camaro's Avatar
I used a Lokar TPI kickdown cable available at Jegs and works perfect.
