Trans question for a 6 liter build
I want to put a 6.0 in my 2001 v6 camaro.
There are many aluminum/iron block motors out there so my question is how do I choose which trans do I go with that will handle the power from a 6.0 with a 10lb nitrous bottle.
Which transmissions will mate up to these motors from trucks or from GTO / c6 vettes?
I can go either way with manual or auto so show me the way:
Modified 4l60e or 4l80e or 6l8oe or a Modified T56?
Any LSx trans will work aside from from corvettes, but even those can be adapted at a competent trans shop. If you plan to keep the trans mounted TA, you'll need a tail housing from a Fbody or GTO, if not the trucks and other IRS RWD cars will work fine. Column shifted vehicles will have a range switch on the trans that you wont use
