Wiring noob
Old Apr 7, 2012 | 01:54 PM
SnowmanLC's Avatar
Default Wiring noob
I got a 6.0L lq4 with a harness, i want to run a t56 behind it. what wiring needs to be removed or added to convert it from automatic to the t56? i do not know what truck the engine came out of but if theres any way of knowing let me know, all i know is the block was a 2004 and before because of the short and long head bolts. thanks
Old Apr 7, 2012 | 02:13 PM
i r teh noobz's Avatar
All you need to run a manual is the VSS plug. All the auto stuff can come out,
Old Apr 8, 2012 | 02:37 PM
m8w6r77's Avatar
lt1swap.com has all the wiring diagrams you need. basically remove all the transmission wiring.
Old Apr 9, 2012 | 07:35 AM
psiconversion's Avatar
LS1Tech Sponsor
You will also want to wire in the reverse lockout.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Apr 14, 2012 | 10:54 AM
SnowmanLC's Avatar
Thanks for all the info, ive been using lt1tech.com that was a big help. but there was a wire left on one of the neutral safety switch connectors and another connector thats grey and green that seems to go to the transmission also
Old Apr 14, 2012 | 06:43 PM
Old Geezer's Avatar
Look on the vertical edge of the block at the bellhsg area... driver side. Should be a set of laser etched numbers/letters there. Post them, and we may be able to better ID the engine...
Old Apr 15, 2012 | 03:09 PM
SnowmanLC's Avatar
I ended up having to get a new block since the original one had a bad spun bearing. I dont have the original block anymore
