Fox electrical
Old Apr 8, 2012 | 08:51 PM
06colorado's Avatar
Default Fox electrical
Been searching for hours on this. When you did the swap how did you get the headlights/turnsignals to work? I know the chassis harness is seperate and all i get is the dash lights to come on, when i turn the lights on the turn signals light up and so does the bright light singal but niether work. ANy one have pictures? Car is an '88.
Old Apr 8, 2012 | 09:01 PM
Revoroller's Avatar
Must be something in your wiring, my 89 didn't have any issues when I pulled the factory engine harness.
Old Apr 8, 2012 | 09:08 PM
zipster's Avatar
Sounds like you are missing the grounds, I would start there.
Old Apr 8, 2012 | 10:58 PM
06colorado's Avatar
That is good place to start. I'll check it and get back, thanks guys
Old Apr 9, 2012 | 09:16 AM
Chrome_Rust's Avatar
in the front corners near the lights on driver and passenger sides there are 2 grounds, one for left and right lighting. If they are not fastened, you will have the problem that you are describing.
here are the locations:
