LS2 swap questions
Old Apr 14, 2012 | 08:57 AM
Houston_t's Avatar
Default LS2 swap questions
So I finally picked up my motor it's a ls2 out of a trail blazer ss, I plan on converting it over to a carb setup and had a few questions. First can I buy the kwik alt and power steering relocation bracket and run my truck accessories ? Also will the truck water pump work with the carb intake ? I see most people change them when they do their swap but that's mostly because they go with the car intake and throttle body. Last how do I tell if my motor is vvt and what tooth reluctor wheel it has ? Thanks in advance
Old Apr 14, 2012 | 02:53 PM
Houston_t's Avatar
forgot to mention what its going in, its a 78 trans am
Old Apr 14, 2012 | 02:57 PM
patooyee's Avatar
Its not VVT and it is 24-tooth reluctor. The TB has truck accessory belt spacing.
J. J.
