Transmission Pans
Old Apr 18, 2012 | 04:38 PM
bczee's Avatar
Default Transmission Pans
I am using a 4L60E in my Nova Swap.. it should be lowered some. Not sure how much clearance I will have around the pan. maybe 4", Once i get it on the ground with full weight, gas, coolant, trans I will see what the final ground clearance is.
What are you guys using for Trans pans. Was considering using a deep Cast Aluminum pan or even the Derale 14204.. anyone use this pan ? (Does it use the standard or deep pickup ?)
thanks
BC
Old Apr 18, 2012 | 07:46 PM
99VetteFRC's Avatar
Had stock 700r4 pan and now th350 pan.
Old Apr 19, 2012 | 05:39 AM
oldgoat69's Avatar
Most of the flow cooler pans use a stock filter/pickup. Beware, I have seen some leak at the cooling tubes, not much but some seepage. I usually use the cast stock depth alum pans, sand blast and paint satin black. Never had a problem with one yet. Some will use a spacer for the filter if they are truck/deep pans.
Old Apr 20, 2012 | 10:47 AM
bczee's Avatar
Oldgoat.. thanks for the info.. well keep that in mind.
BC
Old Apr 20, 2012 | 12:32 PM
the_merv's Avatar
2wd Pan for a 4L60E.
