what water pump...
Old Apr 28, 2012 | 09:13 AM
JAX04's Avatar
Default what water pump...
sorry guys, on phone and can't stand trying to weed through search finds
Is their any truck style waterpumps that will work with the fbody crank pulley and alternator alignment?
I like the top exit, but need it low profile...
thanks.
also, if its not top exit then I can make it work, just low pro like the fbody.
thanks
kyle
Old Apr 28, 2012 | 01:41 PM
brian.harmon1974's Avatar
I'm fairly certain that they use a similar casting. So you can drill and tap for top exit and black off the other. I looked into that for my swap. Another option might be milling the back of the water pump down what ever the offset difference is between the 2. Not sure if u can but its a thought.
