L92 to LS3 Swap info needed
Old May 9, 2012 | 01:21 PM
Sting67ray's Avatar
Default L92 to LS3 Swap info needed
Does anyone sell a complete kit like the GM FEAD 19155066, that will work with the VVT?
Thanks,
Tom M
Old May 9, 2012 | 01:48 PM
85MikeTPI's Avatar
The LS3 doesn't have VVT.
Any truck FEAD or 2010+ Camaro V8 FEAD will clear VVT, but may not clear your frame & hood depending on what you're swapping into.
I'm changing a L92 to a L99 VVT motor and using the C5/C6 FEAD with 1.5" spacers to fit it into a C4 vette. Kwik can do what you want, but it will be pricey.
Old May 9, 2012 | 06:24 PM
chuckd71's Avatar
Dirty dingo has some stuff as well, also not terribly cheap. What is it exactly you are trying to do? Do you have room to just run the l92 fead, or do you not have any of it?
