Gauge swap questions
Old May 13, 2012 | 10:20 PM
thewhizkidnumerouno's Avatar
Default Gauge swap questions
As I understand it, you can swap gauges from an LS car to a non-LS car. I am swapping a '01 LQ4 into a '79 C10.
I know that I could get the gauges from my donor vehicle to work. However, they look like so I don't want to use them. Would it cause a whole bunch of problems if I wanted to swap in gauges from a car? The corvette and camaro guages are good looking and I would use them if I could.
The 4L80E I have seems to be finicky in a lot of respects. Would it cause problems when going over to the car gauges? If it would cause problems, would I be able to go to the newer truck gauges. I saw the gauges in a '08-ish truck and they looked really nice. Would they work with my LQ4/4L80E? Is there any limit to what will and will not work with my drivetrain combo?
My research tells me that I would need the body control module to control the gauges. My research also tells me that I haven't seen anyone trying to swap over truck gauges and I have seen very few people swapping car gauges. Is it going to be more time and money to use a factory cluster versus all new aftermarket gauges?
Thanks to anyone who answers.
Old May 14, 2012 | 01:33 AM
SurWagon's Avatar
I'm trying to use a silverado cluster in my LQ4 swap. The esky guages are not that bad looking. I just tred it without the BCM and I'm not getting everything so I plan on putting the BCM in tomorrow.
Old May 14, 2012 | 01:34 AM
SurWagon's Avatar
Oh, you're going to need the same year(s) BCM, PCM, and cluster. They switched over serial data systems that made switching dificult.
Old May 14, 2012 | 01:44 AM
Todd Neyman's Avatar
do you know if that goes for the 99-02 and 98 as well?
whered you find your info?
Old May 14, 2012 | 12:50 PM
SurWagon's Avatar
Reading through the truck forums. Not sure about the 98-99 dates.
Old May 14, 2012 | 11:08 PM
Well, that answers that question. Thanks.
Now, what about the fuel gauge. What resistance do I use to get it to work?
Old May 15, 2012 | 09:15 AM
SurWagon's Avatar
I'm pretty sure you need to run it though the pcm as it is carried on the serial data line. Not sure of the resistance....I'm going to take thw silverado one and mount it to my pump setup
