DBW pedal mounting
Old May 23, 2012 | 11:33 AM
marcus8171's Avatar
Default DBW pedal mounting
Im doing a lq9 swap into a 72nova. I need help with mounting the pedal assembly to make it work. I have seen it here before but can't seem to find it.
Any help will be greatly appreciated.
Thanks again.
Old May 23, 2012 | 11:57 AM
Kingstir's Avatar
Default pedal mounting
you could place it where it needs to be and mark for drilling 2 holes and bolt in place with a couple of 5/16 bolts/ nuts/ washers. I opted to weld 2 studs to the
inside firewall location to keep the outside area clean. I spaced the pedal back with a 3/8" washer so that the weld wouldnt interfere with the flat back of the pedal assembly. works well.
Blanchard- 70 el camino
Old May 25, 2012 | 11:17 AM
marcus8171's Avatar
Kingstir thanks for your help this is my weekend project to get it mounted
Old May 25, 2012 | 03:18 PM
Stu Cool's Avatar
I made a simple bracket and bolted to the studs that hold my brake booster/pedal in place. You can see it here:
http://www.hotrodders.com/forum/jour...age=5&reverse=
Pat
Old May 25, 2012 | 03:37 PM
-TheBandit-'s Avatar
What kind of pedal are you using?
Old May 25, 2012 | 03:39 PM
Old Geezer's Avatar
Talking Here's a....
55 Chevy mount....
The pedal is out of an 05 Silverado. I cut the arm off, offset it to the left about 1.5", and changed the pad angle to suit my foot position.
I plug welded the brkt on the firewall B4 the car was painted..
Attached Thumbnails DBW pedal mounting-pedal-mount-001.jpg   DBW pedal mounting-pedal-mount-004.jpg   DBW pedal mounting-pedal-mount-003.jpg   DBW pedal mounting-foot-pedal-001.jpg   DBW pedal mounting-31812-55-pics-012.jpg
Old May 25, 2012 | 03:50 PM
Don't forget to look through these threads; I'm sure you'll find a number of ideas:
https://ls1tech.com/forums/conversio...ap-thread.html
