Harness connectors/sensor differences?
Old May 25, 2012 | 05:47 PM
2ndgener's Avatar
Default Harness connectors/sensor differences?
I'm looking at a ls1 or ls6 intake for my 02 5.3 swap into 70 camaro. I am familiar with some of the fitment issues with the water pump and coolant steam port crossover. My real question is do all the sensors and or injectors use then same harness connector. So will my 5.3 harness connectors connect to all sensors and injectors on either the ls1 or ls6 intake?
Old May 25, 2012 | 08:27 PM
Steve01SS's Avatar
The injector connectors are different for LS1/LS6 injectors vs. the 5.3 injectors. You can cut the plugs off and splice on the correct EV1 style connectors.
Old May 25, 2012 | 09:24 PM
2ndgener's Avatar
thanks for the help
