Heater Hose Plumbing
Old Mar 30, 2004 | 09:48 PM
LS1Sandrail's Avatar
Default Heater Hose Plumbing
I have an LS1 in my sandrail and am about ready to fire it up.
I still have to either cap off the heater ports or loop them, Can anyone offer the best approach?
Is getting the air out of the motor a problem?
Old Mar 30, 2004 | 11:00 PM
gEtyOPaPiOn's Avatar
when my heater core set up wasnt ready i had it looped ....what is the air motor problem ?
Old Mar 31, 2004 | 06:16 AM
skonka's Avatar
As long as you have the steam line plumbed to a point of the radiator (or other area) higher than the motor you should be good. You won't have any problem with trapped air but I'd loop it off rather than cap each.
S
Old Mar 31, 2004 | 07:04 AM
S
I don't want to sound stupid here, but what is the 'steam line' and where do I find it on the engine?
Old Mar 31, 2004 | 11:01 AM
70 LS1's Avatar
Conversion master
The steam line runs fron the cylinder heads under the intake manifold through the throttle body and back to the radiator.
Old Mar 31, 2004 | 10:17 PM
Budman78's Avatar
Launchin It!
I just drilled mine out and plugged them with freeze plugs.
Old Apr 1, 2004 | 07:23 AM
ezzzzzzz's Avatar
You mean you drilled and plugged the steam lines exiting the heads??? Without those lines, air pockets in the heads turn into steam and you'll have serious problems in no time at all. These are there to bleed the air pockets off into the coolant sytem and allow coolant to fully displace that air. You can't get by without them.
Old Apr 1, 2004 | 09:40 AM
coachreed's Avatar
First things first... I WANT AN LS1 Sandrail! Thats freakin awsome! I think I know what I plan to do in the future! As for the steamline(s)... ya know how they say, "you learn something new every day!"... well, I learned my something already now... does that mean I can check out until tomorrow? Or does that mean I might learn more than normal today?
Later!
Coach... I mean Randy (I often forget who I really am)
Undergoing LS1 Conversion as we speak!
Click Image to Visit My Website!
Old Apr 1, 2004 | 08:45 PM
Budman78's Avatar
Launchin It!
I think the topic is on Heater Hoses. Someone else started the steam line. I plugged the heater outlets.
Old Apr 2, 2004 | 01:58 PM
Default LS1 Sandrail
[img]https://ls1tech.com/forums/attachment.php?attachmentid=6017[img] Here's a picture of it.
