SBC Clutch on the LS1?
Old Jun 15, 2012 | 11:29 PM
badazz81z28's Avatar
Default SBC Clutch on the LS1?
Does anyone know if the 11" SBC clutch/pressure plate will bolt on the LS1 flywheel?
I have a very low mileage Centerforce on the 90s 350 engine (Gen1). I paid too much $$ for it to go to waste.
Thanks,
Old Jun 15, 2012 | 11:38 PM
i r teh noobz's Avatar
I have an SBC clutch on my Sachs 1050 (4.8/6.0) flywheel. A few holes in the pressure plate need enlarged a touch and two dowel pins have to come out of the flywheel. And you need metric bolts. The old 3/8" SBC bolts will thread in, but strip out when you tighten them down.
Old Jun 16, 2012 | 06:33 AM
garys 68's Avatar
The 11" clutch will bolt to the sachs flywheel, but not the LS1 flywheel.
https://ls1tech.com/forums/conversio...-ls-motor.html
Old Jun 16, 2012 | 07:05 PM
I have a centerforce clutch. The pressure plate has numerous mounting holes compared to the stock pressure plate which only has the required holes. I guess when I pull it, I will have to line it up and check.
Old Jun 16, 2012 | 07:55 PM
garys 68's Avatar
When I picked mine up, I made sure everthing lined up at the Oreileys counter before I paid. Easy to return when you havn't even left the store.
