Need a procedure to check TPS and APS.
When I powered up the computer for my LS3, everything looked good except I got DTC's all relating to the TPS and Accelerator Pedal sensor.
P0122
P0223
P2122
P2127
P2119
The engine has not been started yet. If I turn the ignition on and press the accelerator, the butterfly moves, so it appears to work.
The engine, accelerator pedal, and computer all all matched and original to each other (2010 Camaro LS3).
I have the wiring diagram for the car; does anyone have a diagnostic procedure I can use to troubleshoot this? The harness is the factory harness that I had reworked by Speartech. It could be just a bad connector or something, could even be a bad sensor, but I'm not sure exactly how to troubleshoot it. I've read stuff online about checking reference voltages and sweeps, but nothing for this application.
I'd appreciate even a generic diag procedure for this.
Thanks
http://www.ssgm.com/news/taking-a-fi...cs/1000326441/
So, in short, there was nothing wrong with my setup, all I needed to do was start the damn thing and let it run for a bit
. If your engine computer is pre-09 then this doesn't apply to you.
