Lsxfox torque converter lockup questions
Using a modified harness and there's a green w/ white stripe wire for torque converter lockup. I've been told to just run it to my brake light switch but I'm unsure.
Do I need to wire it to a relay or is the switch only fine?
Then which side of the switch? Does this need to be a constant power to the PCM and when the pedal is pressed it breaks the 12v and that how it works or is it backwards to how I described?
I'm really confused so please help, you've helped me a ton so far this community is awesome when it comes to lsx knowledge.
Thanks guys
I'm so confused by these directions. Can you draw this out for me because I only have the one wire so how do I use 2 terminals?
http://www.maliburacing.com/josh_mal...e_switch_2.JPG
