Overheating in my daily driver.
Old Jun 29, 2012 | 05:31 PM
  #41
the_merv's Avatar
Veteran: Air Force
That's a good way to do it.. I fill the cooling system up in a similar manner.
Originally Posted by bigpat1802
I had this problem on my 2000 5.3 as there was a huge air pocket in the intake manifold.
However, this is confusing..
Old Jun 29, 2012 | 06:59 PM
  #42
vannatta20's Avatar
Been busy moving out of my place this week. Going to jack the truck up and bleed it that way. Getting a low mile water pump as well for to try that out. I think it's the radiator or pump. The ls1 radiator was used. When I pull the pump I'll take the radiator and have it tested. The faster I go the higher it over heats. It doesn't want to cool down after that at idle.
Old Jun 30, 2012 | 01:59 AM
  #43
the_merv's Avatar
Veteran: Air Force
Have you ensured the mix is 50/50? Seriously...
Let's cover what has been done instead of what you are goin to do.
Old Jun 30, 2012 | 09:50 AM
  #44
vannatta20's Avatar
Yes it was 50/50 mix. I doubled checked my used coolant containers. Thanks for all the help guys.
Old Sep 10, 2012 | 01:31 PM
  #45
vannatta20's Avatar
Finally back from my trip. Ordered a new aluminum 2 core radiator for the truck while I was gone. Installed it a few days ago and have been driving it since. It stays @180 now while at highways speeds where before thats when it would over heat. Its fixed! the LS1 radiator was either bad or just didnt have enough cooling capacity for my heavier truck. Sorry for the long wait on the fix.
Old Sep 10, 2012 | 03:52 PM
  #46
Psychopjv's Avatar
I had the same problem in my ls1 240 turned out the radiator was junk. Mine was getting 210-220 after hour of driving. I swapped waterpumps tstat. I put the front end 3 feet up and it would still bubble out coolant. I finally learned the radiator was bubbling fluid and not flowing
