Need some help
Old Jun 24, 2012 | 09:33 PM
mmarty71's Avatar
Default Need some help
Hey all, been awhile. I want to get going on my lq4 stand alone harness project but I ran into a problem. The harness is intact except all the trans stuff has had the plugs cut off. Where can I get the connectors? So far here's what I have. off the red pcm numbers 20,21,62,51,47,8,6,2,58. off the blue pcm 32,34,72,17,18. and off the black c2 from fuse block 2 green,purple/white,yellow,2 pink. All these wires have been cut at the trans (or near it).
Old Jun 25, 2012 | 06:35 AM
psiconversion's Avatar
LS1Tech Sponsor
What year is the swap? We have pigtails for the transmission if you need them. Give us a call at 732-691-6531.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Jun 25, 2012 | 09:52 AM
mmarty71's Avatar
The engine is a 2001 and I am using a 4l60e trans. I want to get the wiring set up so I can use the engine in whatever I want.
Old Jun 25, 2012 | 12:24 PM
LS1Tech Sponsor
Ok. We have the pigtails (TRANSMISSION and VSS) if you need them.
Jon
PSI
__________________
Ebay Store
Old Jun 28, 2012 | 12:48 PM
mmarty71's Avatar
How much would the fittings be?
