Mounting ECU
Old Jun 29, 2012 | 02:02 AM
1970-Cloned's Avatar
Default Mounting ECU
1970 Chevelle with an LS2 and a speartech harness with extra length.
I want to mount the ECU to the top of my glove box under the dash. Will the computer overheat or will it be fine?
I am test fitting the after market AC duct work and trying to figure out where the ECU should go. This place seems like it will work good.
Old Jun 29, 2012 | 07:43 AM
psiconversion's Avatar
LS1Tech Sponsor
ECU Should be fine up there.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Jun 29, 2012 | 08:26 AM
bczee's Avatar
I have mine in side and on top of the Trans tunnel, it is incased in a small console. Have had not problems.
The Inside of an engine bay is a lot hotter then anywhere inside your car. You should be fine.
BC
Old Jun 29, 2012 | 09:41 AM
I figured it would be ok. I just know heat is a killer for computers.
As long as the heat sinks are up can the flat side of the computer touch the top of the glove box? I do have the plastic carrier the computer came with and that would allow some space between the two with some heavy modification.
Old Jun 29, 2012 | 09:50 AM
bczee's Avatar
I would think that it would not hurt anything since the Glove box is cardboard.
But would also think that the plastic holder almost isolates the PCM from touching anyhthing.. with that being said.. I would try and keep it isolated from touching anything other than what the OEM holder touches (or the same area or part), if possible.
just my 2 cents..
BC
