Need some help with lq4
)and was told it would be at least 1000 bucks to take the old truck harness out and make it work for my car (I really dont do wiring and dont want to burn my car down with my crappy wiring job) planning on running a 4l80e so would an ls1 harness even work for that? Any help would be appreciated! If money is an issue I would run the motor as is get it swapped in and get it running then worry about mods later as head swaps are easy.
http://www.lt1swap.com/
As for heads, etc. Just get the engine in the car, then see if you want more power. I was going to do the L92 heads on my LQ9, but found it was fine stock in my 68 vette.
If you are going to go with L92 heads, as stated above you will need an LS3 intake which will require different connectors for the injectors and possibly the MAP sensor, depending on the year of the LS3 intake.
Jon
PSI
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
If your on a budget that seems the way to go. I wouldn't go to radical with the cam; as stated above ls6 would be a good choice. I know you probably don't like the ugly truck intake but if you search this site there have been a few people who have cut the plastic pegs off sanded and painted their intakes, and they look pretty good compared to stock!
I wouldn't go ls3 on heads; your on a budget and to go that route you'd have to buy different intake and injector harness. As stated above look for some 243 or 799 heads, but honestly the 317's aren't to bad, just lower compression.
Good luck!
Also, one will need a electronic adapter box for the LS3 DBW 90mm TB to the earlier truck DBW TB. The truck Gen III MAP can be made to work in the LS3 intake with the correct Oring as the holes are different sizes.
Here are the factory specs on an LQ4 (but lost who posted and can't give credit) :
4.000" bore
3.622" stroke
6.098" rod length
1.338" comp. ht. pin location
-6.7cc dish piston
71.06cc chamber
0.051" gasket thickness 4.010" bore
9.24" block deck height
Good luck!
Youc could als do a TBSS/Gen IV 5.3L intake swap. Its 87mm intake and TB. Then you would still need a TB adapter box for the 87/90mm Gen IV TB to Gen II harness. You can get the X-link form torquerush.com couple hundred bones but you get a better flowing and larger intake than the regular truck 78mm unit.
Jon
PSI
Ebay Store
Have you run it to the track yet?
