ls3???
Old Jul 12, 2012 | 03:37 AM
dave123's Avatar
Default ls3???
other then money what do i need to put an ls3 in my 2000 z28
Old Jul 12, 2012 | 06:26 AM
SA_swaps's Avatar
24x crankreluctor,24x crank sensor,ls2 trimming chain set, ls2 cam sensor. Will have to extend your cam sensor wiring. Depending on what your doing with intake,may need throttle body.
Old Jul 12, 2012 | 06:55 AM
psiconversion's Avatar
LS1Tech Sponsor
You will need to change the throttle body to a 4 bolt Drive By Cable (edelbrock, etc, are options). You can also use a Lingenfelter 58x to 24x conversion box instead of changing the cam and crank reluctor.
MAP, MAF and Fuel injector connectors will also be different.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
