brents 69 camaro build
its at paint right now. this is an original v8 car in factory orange... going back to orange with white stripes.
and the donor car: 1999 firehawk
this is a 327hp ls1 with auto transmission. 57k original miles.
i need to find out if i can use the brakes off of this thing, and i need to choose which motor mounts to use, need a gas tank with pump, need headers, and rims, need a radiator.
any suggestions would be highly appreciated!
I chose Hooker ceramic headers 1-HKR for 67-69 Camaro. Hooker motor plates (I'll get back to you with the model #)-there are choices with Hookers that give you varied clearances. With Hooker plates, I was able to use my stock oil pan (no modifications or cutting/no welding).
Other folks will have varied reasons for using other brands of plates. They're all worthy reasons, and you can choose your preference.
Energy Suspension poly motor mounts.
Don't know what your budget is, but the stock radiator could do, for now. I have a BeCool direct fit for 67-69 Camaro. Hoses will have to be adapted.
Stock fans can be adapted to the BeCool, if need be.
Best of luck with your build!
as for the radiator, you can easily make mounts for the firebird radiator if it is good. Simple mig welding of some 2x4 steel made mine. should be plenty of room, you should not need a shroud these run really cool. my fan never came on until the tuner lowered the temp to 180.
I put a gas tank from a 1998 impala in mine. Not sure where your gas fill neck goes, but sure there is something you can just hang somewhere.
good luck.
https://ls1tech.com/forums/conversio...ss-ls-t56.html
Got a summit number on the energy susp poly mounts gmag?
This combination will cause the engine to sit slightly lower than other brands. I had to shave the bottom screw on my alternator to clear the crossmember. Not a big deal.
back from paint
motor out of firehawk
front upper and lower control arms replaced and front drums replaced with the firehawk disc brakes
now i need to send off the pcm... any suggestions on a reputable person to program?
