Truck is giving me hell
Here is what we have done:
1. I moved the grounds for the PCM from the body to the motor. All of my grounds for the engine/PCM are now on 1 ground on the back of the motor. I have 4 grounds from the PCM (pins 1 & 40 on each connector), 1 for each coil bank and 02 sensor and 1 for the MAF/IAT sensor.
2. hooked up noid lights to the injectors and 1, 3, 2, and 4 injectors weren't lighting up.
3. I checked all the injectors for keyed 12v and they all had 12.3v
4. Next I checked the continuity of the injector wires from the pin for the computer to the injector and all of them had connectivity.
5. I also swapped the injectors around to see if the problem followed the injectors but I wasn't sure if it made a differnece bc I could un hook all plugs from 1 side and no matter which 1 i hooked up it seemed to run a little better. This is where I stopped bc I ran out of time.
After talking to a buddy about how the noid lights worked I have come to the conclusion that it probably isn't an injector issue but probably either wiring or the actual computer itself. After reading and researching I have found out that there are drivers in computer for the injectors but I can't find out which injectors go to which driver anywhere. If I knew that it would help out. I am not sure where to go from here and I am tired of chasing our tails. I followed everything on LT1swap.com to a tee.
On a side note, have you replaced the spark plugs? Sometimes when first getting one to run, you'll foul out some and wont think of replacing them because they're new. I have personally done this, and new plugs was a cheap easy fix.
