IS300 LSx Build / Initial Startup
any help would be greatly appreciated
The headers I used came with my motor, an 07 LQ4 out of a Chevy Express van. Glad to see you got this bad boy running. I wanted to thank you again for the braided hose assembly link. Its exactly what I needed. If you don't mind one more question.. how did you cut your black hose?
thanks in advance!
6psi: 488whp/483wtq
12psi: ran out of fuel at 5500rpm, aborted run, 588whp/588wtq
Im going to try and put some weight in the trunk and get the 60' down. If the car would 1.7 60' I think it would 10's. O well, time for a limited slip and some weight!
Heres an article LSXtv.com did on the car on 10/2/12....
Swap Insanity: Turbo LQ4 Powered Lexus IS300 - LSXTV
