E38 ECM Brake Switch Wiring
With the dual switch when the brake is applied there is twelve volts applied to the blue/white wires. When the brakes are off there is a ground through the resistor to ground simulating the bulb. From my GM schematics, there is a built in resistor in the ECM. Same with the TCM. So they can take a straight shot of 12V from an ignition on source. Fuse 44 on my schematic.
On my car I have A/C. I have provided a relay so that anytime the A/C is on the high speed fan also comes on. What this A/C relay does is provide a 2nd ground for the high speed fan relay. EMC X1-17 provides the other ground for normal circumstances.
Is the Powertrain Control Relay even needed?
Everything I have read has people deleting this circuit and just tying all of the ignition wires into a key-on 12v+ source.
I'm just finishing up my harness as well...and I removed this pin (didn't cut anything, just unpinned it).
Thanks.
Thanks.
If others have done it differently with no problems then I don't know.
