what does mlp switch actually control
Old Aug 4, 2012 | 12:12 AM
ealvarez11's Avatar
Default what does mlp switch actually control
i have not found answer yet as to what mlp switch actually does besides indicate shifter position. what does it actually tell pcm and how does it affect the setup if you don't have one? do you even need one for lsx swap?
http://i291.photobucket.com/albums/l...t/IMG_0512.jpg
Old Aug 4, 2012 | 12:23 AM
Bo185's Avatar
Those are PNP switches. The twop plug is the early style and the single is the later one around 04 or 05 up IIR. They provide neutral safety, backup lights, cluster gear position, and PCM gear position. It tells the PCM what gear your in, although it doesn't really need it as it can be adjusted for. Also need it for a crank relearn to tell PCM its in park.
They are not needed for a swap unless you want to use it for backup lights, N/S etc... Easy to keep or remove.
