G8 bolt pattern and Camaro bolt pattern
Old Aug 14, 2012 | 06:11 PM
Blazincopper's Avatar
Default G8 bolt pattern and Camaro bolt pattern
The 1967 Camaro wheel bolt pattern is 5x4.75 or 5x120.65, the G8 bolt pattern is 5x4.72 or 5x120. Is this close enough to interchange parts? I am planning on ordering Wilwood front wheel hubs and put the Ponitac G8 rotor on them, then make a bracket to use the G8 caliper. is .65 enough to matter or has anyone else done a similar project or swapped wheels between the 2?
Old Aug 14, 2012 | 09:31 PM
LS1MCSS's Avatar
No, it's not close enough.
Old Aug 14, 2012 | 11:39 PM
sierrac3_s2000's Avatar
You couldn't run the wheels with the different bolt patterns, that would be unsafe. However if you just want to put the rotors onto the hubs then re-drilling them to the correct bolt pattern is easy and would be perfectly fine. You would still need 5 x 4.75 wheels to match the pattern on the hub.
Old Aug 15, 2012 | 02:19 PM
thirteen20z28's Avatar
I wouldn't be surprised if those G8 rotors slipped right on the Wilwood hubs, we're only talking maybe 0.65 millimeters here, guys (depending on tolerances).
I am aware of several W-bodies (Grand Prix, Regal, 00+ Impala) running Mustang wheels without a problem. Technically, the W-body lug pattern is 115mm, and the Mustang pattern is 4.5" (114.3mm). Heck, even F-body rotors drilled for the 4.75" pattern slip on the 115mm W-body hub.
Old Aug 15, 2012 | 06:29 PM
claytonisbob's Avatar
Don't a lot of Chevelle and Camaro guys run BMW wheels which are the 5x120mm bolt pattern? .65mm is really freaking small.
Old Aug 15, 2012 | 06:57 PM
Krom's Avatar
.65 mm is .025 inches
IMHO the wheels and rotors will bolt right on like they where made for each other.
Old Aug 15, 2012 | 09:19 PM
I am going to order the hubs in the next couple days - so I'll let you know. Anybody know of any other less expensive hubs than the wilwood hubs?
