What size drill bit to drill alt hole on block?
Old Aug 18, 2012 | 11:30 AM
Builtz71's Avatar
Default What size drill bit to drill alt hole on block?
I'm needing to know what size bit you guys used,to drill the alt hole out on a lq4 block?...thanks
Old Aug 18, 2012 | 11:51 AM
BOXCHEV's Avatar
I think drill bit sized needed is 8.5mm or 11/32 for a M10X1.5 tap.
Google metric drill/tap chart and you should find your answer.
Old Aug 18, 2012 | 03:13 PM
Builtz71's Avatar
Cool,thanks man!
Old Aug 18, 2012 | 08:43 PM
STEEPSS's Avatar
Be sure to bolt your alt up, and use it as a guide, or build a jig, that way everything lines up right.
Old Aug 18, 2012 | 09:15 PM
Rick Speed's Avatar
The actual drill bit for that tap is a "r"
