Simple wiring question using 99 5.3 pcm
Old Aug 20, 2012 | 01:57 PM
superbean's Avatar
Default Simple wiring question using 99 5.3 pcm
with help of lt1swap.com.. helping a friend wire in his 5.3 into a 71 c10. The rest make sense but Blue Connector, Pin 33 - TCC Brake Switch. Does this need to be hooked up or can it be removed? Will be running a TH400 transmission and it's said its for lock up torque converters. (converter is non lockup)
Thanks - Randy
Old Aug 20, 2012 | 03:15 PM
Chrome_Rust's Avatar
you can delete it. Did you keep the VSS though and remove all the other trans wires?
Old Aug 20, 2012 | 05:45 PM
superbean's Avatar
I will not be using an electronic speed signal as the truck's speedo is mechanical and output on trans is mechanical.
Old Aug 20, 2012 | 07:11 PM
then remove it all. you are good.
