Is my frame bent (G body)
When the car was on the ground it had a little bit of a lean, but i had charged that off to the 30yr old springs since it didn't appear to have signs damage.
Today I pulled the old V6 out and seen this
The scrapes in the front are just a quick pass with the scraper.
Here you can see the outline of the motor mount. The bend follows the fromt edge of the mount perfectly like it is supposed to be there. No damage to the mount it sit flat on the garage floor.
Drivers side is what is in question.
Here you can see the drivers side mount angles slightly to the front.
let me know what you guys think. I have not seen or heard of this being normal, but this is my first build. Any frame or body guys if you could chime in let me know what are some signs to look for of old repairs. Thanks
Now the question is repair or replace. Since the frame is coming out regardless I'm leaning towards replacement. But I need to research frame alignment cost in my area vs a good frame.
Since you are building a custom car with aftermarket or custom engine mounts, the only thing that matters is: are the suspension and body pick up points in the proper spots and is it solid. If so, game on!
That frame is crunched. The pads should be flat. Only way to tell how bad is, is to put it on a frame machine. Around here, it usually costs in the hood of $3-400, to set up, check and pull.
