GM Communication port
Old Sep 1, 2012 | 10:00 PM
Tramminc's Avatar
Default GM Communication port
Can any GM port work to program an LS motor?
The part is normally under the dash on the driver side.
Old Sep 1, 2012 | 11:18 PM
bczee's Avatar
What car / truck are your refering to ?
If your referring to the ODBII port, yest that is the port you can used a Scanner or one of the hand held programer. You can also use your laptop if you have the software (HPTuner, EFILive, etc) and cables.
Old Sep 1, 2012 | 11:29 PM
i r teh noobz's Avatar
The OBD2 port? Pretty much any GM port will work. Mine came from an Alero or something from the 90s.
Old Sep 2, 2012 | 08:38 AM
99MUSTANG5.3L's Avatar
It has to be from a vehicle with OBDII. Which started in 96. There is a pinout on www.lt1swap.com.
Old Sep 2, 2012 | 12:48 PM
Tramminc's Avatar
Thanks, next week I go to the junk yard.
