to complete cars need help
I dont know if i should use the steering column as well? anyway because of my limited experience i would like somebody to tell me the easiest way to approach the electrical situation inside the car,
should i put the 3rd gen wiring aside and then just put the 4th gen wiring over it should i cut into the 3rd gen wiring, the only thing i dont care about moving over will be the air bag stuff that it......
anyway any help would be really appreciated guys
Wiring is pretty easy, just dive in and you'll figure it out. If you look at it as a whole, it looks way harder than it is.
lt1swap.com has great LS harness information.
Search a bit, I'm sure there's a 3rd gen swap thread here you can look at for ideas. The engine swap should be fairly simple. Some people end up swapping the dash and interior as well.
You will also need to modify the 4 th gen harness for standalone unless you plan on using a 4th gen gauge and instrument cluster...
Lt1swap.com is great when it comes to the harness
