fuel filter fittings ???
Old Sep 23, 2012 | 06:40 PM
not2oldchevy's Avatar
Default fuel filter fittings ???
I want to use a factory fuel filter from a avalanche but I can't find any Oring type fittings to run a 6an line to. Anybody know of these fittings? Thanks
Old Sep 23, 2012 | 07:38 PM
x275radial's Avatar
jegs.com just type in ls1 or lt1 fuel fittings
Old Sep 23, 2012 | 09:02 PM
MikeFSKSpeed's Avatar
I have them from Russell in stock of needed
Old Sep 24, 2012 | 02:19 PM
Can't find them, this filter is on a return type system. It has female ends and takes a Oring type fitting.
Old Sep 24, 2012 | 05:49 PM
John McGraw's Avatar
You can make this type of male fitting on the end of a piece of tubing, or you can go to your local auto parts store, and they will sell you a piece of line with the proper end already on it. If you know somebody who has one of the Mastercool hydraulic flaring tools, it will make these fittings. I make them all the time.
If you need the female fittings, avoid the ones with the plastic release clips. Russell now makes a fitting that uses a screw-in retainer to keep the fitting on the tube. I have had 2 of the plastic retainer clip fittings come loose in use, and would not recommend them to my worst enemy! I went back and pulled all the plastic clip fittings that I have put on cars in the last several years, and replaced them with the new style fittings.
Regards, John McGraw
