LS3 Intake map sensor options??
Old Sep 24, 2012 | 11:08 AM
busta9876's Avatar
Default LS3 Intake map sensor options??
I've got a 2010 LS3 intake with the bolt down MAP sensor. I understand the voltage slope on this sensor is slightly different then MAP sensor used on most Gen 3 Vortec/LS1. I'm using a LQ4 Gen 3 block and LS1 harness/411 PCM so I need that type of MAP sensor. Is there a part# for a sensor that will bolt on like the LS3 and have correct voltage slope?
Old Sep 24, 2012 | 11:15 AM
hookemdevils22's Avatar
Man, the electrical guru is asking questions? Is this bizarro ls1tech?
Just make a bracket out of some scrap metal and use an o-ring with a larger OD. It's quick and easy.
Old Sep 24, 2012 | 05:55 PM
Rick Speed's Avatar
Yeah a lot of guys have been just siliconing the fbody one in. That's what I did but my tbody bracket kinda holds it in too.
