LS into a 95 Bird, AC question
Now I can live without the CC if I have too but not the AC so I am wondering if anybody tackled this? do you use your old AC and lines or did you use a 98-2002 AC and lines? And if you used the old LT AC did you have to change the pulley and connector?
Also did anyone tackle the CC issue.. I would love to hear what you did.
Ponch
As for the AC I used the LT1 system including piping, accumulator, condenser and evaporator. The only part changed is the compressor with its pulley. I had to use spacers on the front sway bar to clear the AC lines, since they now pass below the compressor.
Assuming the compressor connector I think they're the same but I used the one with the LS1 wiring that I worked on to adapt to my car.
