Park/Neutral safety relay control
Old Oct 6, 2012 | 06:20 PM
L.E. Day's Avatar
Default Park/Neutral safety relay control
Trying to set up a relay for a park/neutral safety switch in a 2007 5.3 (L59)/4L60E conversion. can I use that light green (switch signal) wire from the PNP or the dark green (clutch start signal) wire from the PNP to trigger the relay?
Old Oct 7, 2012 | 06:28 PM
L.E. Day's Avatar
Default Neutral safety switch
BAck to the top
Old Oct 7, 2012 | 06:58 PM
T76s10's Avatar
I grounded mine because the switch i had didn't work. I just make sure that i don't start it up in gear although i have dune it once before
Old Oct 16, 2012 | 06:18 PM
L.E. Day's Avatar
Default PNP trigger wire
Back to the top
Old Oct 17, 2012 | 03:57 AM
ls1nova71's Avatar
The light green wire pin 8 on the PNP switch is the shift interlock, may only work in park, not sure. The dark green wire pin 1 is the starter relay wire. From the ignition switch, the starter wire should be hooked to pin 12, pink wire on the PNP switch. Then pin 1 dark green would go to the starter relay on terminal 85. Relay terminal 86 goes to ground. Terminal 30 would be 12v constant and terminal 87 will go to the starter solenoid.
Old Oct 18, 2012 | 05:57 AM
veltboy618's Avatar
What did you have to ground to bypass the switch?
