T5 vs T56 bolt pattern
Old Oct 10, 2012 | 05:40 PM
mannytheman's Avatar
Default T5 vs T56 bolt pattern
might be posting in the wrong section but...
I have an LS1 to T56 bellhousing, will a T5 fit instead?
Also 94 V6 camaro 5spd...that is a t5 right?
Old Oct 12, 2012 | 12:45 AM
bww3588's Avatar
What are you trying to do here?
Old Oct 15, 2012 | 11:02 AM
I want to put a t5 on a t56 bellhousing.
Old Oct 15, 2012 | 12:31 PM
R6cowboy's Avatar
Will not work
Old Oct 15, 2012 | 01:38 PM
Thanks guys
redbird555's Avatar
getting a t5 to fit a t56 bellhosuing wont work. you can bolt a t5 to an ls1 however. although it wont last very long even if its built
Old Oct 15, 2012 | 06:12 PM
thesource's Avatar
That particular T5 uses a Ford front case and bolt pattern. You could probably use it on an older GM aluminum passenger car bell housing if you re-drill the bolt pattern. I am not sure if the depth of the bell housing vs. the input shaft length will work out though.
Old Oct 16, 2012 | 08:25 AM
I already have the tremac ls1 to t56 bellhousing so I'll keep looking for a t56.
