Quick steam pipe question -LM7/S10
Old Oct 15, 2012 | 11:02 AM
Ryan Mills's Avatar
Default Quick steam pipe question -LM7/S10
I'm thinking about getting one of those metal radiator hoses to run from the 5.3 waterpump to the 4.3 radiator, but I would have to relocate my steam pipe tap....could I just tee it into the 5/8" line that runs to the heater core? That seems like an easy way to do it, but I want to make sure there wouldn't be any problems with doing so. Thanks!
Old Oct 17, 2012 | 06:44 AM
Sarg's Avatar
There was an article on pirate 4x4 that talked about this and said that was an option. They also said it would be better to run a resevoire before returning it to allow air to rise to the top of the coolant system.
Old Oct 17, 2012 | 09:06 AM
74modified's Avatar
The factory ran the steam vent to the heater return line (to the water pump)on the Trailblazer SS, so its probably OK. I like to vent to a higher point and use a surge tank with a vent line conection (like most late model factory setups).
Old Oct 17, 2012 | 05:34 PM
74novacustom's Avatar
ive got my vent running into the top of my waterpump and is fine. just drilled and tapped it.
Old Oct 19, 2012 | 09:16 PM
markbsae's Avatar
Late model GM cars many times don't have a valve in the supply and return to the heater core. They are a constant flow. If you tap your steam line into the water pump return from the heater core and you are using a valve in your heater core you might get flow issues. It doesn't have to flow much though.
