ECU location for Fox/LS swaps?
Old Oct 19, 2012 | 09:04 AM
ardavis78's Avatar
Default ECU location for Fox/LS swaps?
Where is everyone locating their ECU's on Fox/LS swaps?...Are you having to extend your wiring? I'd like to mount it inside the car and keep the engine compartment clean...Let me know..Thanks
Old Oct 19, 2012 | 09:53 AM
LILHEMI's Avatar
in for pics. been thinking about this lately as im getting real close to running my harness.
Old Oct 19, 2012 | 10:09 AM
ardavis78's Avatar
Me toooo...
Old Oct 19, 2012 | 11:32 AM
RATBOX's Avatar
On my 90 LX with using a speartech'd 01 camaro harness I ended up with just barrrely enough room to mount it against the firewall just above where the passenger's feet will be. If you have the heater box out, it makes things a lot easier to keep it "up in the dash" and out of the way. If you want to take it any farther, you'll need to extend the harness.
Old Oct 19, 2012 | 11:54 AM
1bad03snake's Avatar
Mine is in the stock mustang location.
Old Oct 19, 2012 | 01:54 PM
psiconversion's Avatar
LS1Tech Sponsor
For what it's worth, we provide 4-5 ft of harness length from the rear of the engine to where the PCM mounts.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Oct 19, 2012 | 02:10 PM
LS1PUNK's Avatar
Mine is in the stock location as well.
Mounted it to a plate.
http://www.jegs.com/i/JEGS+Performan...40680/10002/-1
Old Oct 22, 2012 | 07:23 AM
ardavis78's Avatar
Lotsa good ideas....Anyone else?
Old Oct 25, 2012 | 07:46 PM
streetlegalls1's Avatar
PSI here
Old Oct 26, 2012 | 12:11 PM
willj313's Avatar
PSI here to jon is a great guy to work with
Old Oct 26, 2012 | 12:47 PM
groundczero's Avatar
In my 85 I relocated the battery to the trunk, and put the ECU there.
Old Oct 26, 2012 | 12:57 PM
ardavis78's Avatar
Not a bad idea...I'll prolly move the battery too...
If anybody else has any ideas, don't hesitate....Thanks!!
Old Oct 26, 2012 | 03:07 PM
superbean's Avatar
Depends on which harness you are using? F body or are you using a Truck setup? Truck harnesses are a gaudy in stock form and put the pcm in a junk location for a fox, however, you can pull the wiring from the pcm back around where it runs to the intake, and instead of extendeding 40 wires to the pcm, you can elongate the Alternator, tps, iac, cts, injectors, cam sensor to fit, which is only 28 wires to extend about 4 ft to put it in the passenger kick panel. Not too hard to do once you unloom the whole harness and have it sitting in the car.
If I had a stock harness to work from, I'd save the money, convert it, lengthen it, shorten, etc., because building a sub fuse box only cost about 50 bucks in materials tops, but if you had to buy a harness, I wouldn't waste the time, Id spend the money on a PSI harness as its already longer than factory and nearly plug and play
Old Oct 28, 2012 | 07:42 PM
Bowtiedford's Avatar
right above the glove box door. I removed the far passenger vent tube to make room
Old Oct 29, 2012 | 07:49 AM
ardavis78's Avatar
I already have a stock F-body harness...Thnx a lot for the input tho...Every little bit of info is a huuuuge help...I'm planning on using the T/A gauge cluster too....I have a COMPLETE harness to use from headlights to taillights!...I'd like to to look factory but very clean...Thanks again!
Old Oct 29, 2012 | 07:50 AM
ardavis78's Avatar
AHHHHH...Good idea!!...Thnx
