LS or LM swap
As far as the LS or LM motors..!? the LM7 is an Iron block 5.3L and the LSx is an all aluminum engine.. depending on which one you get. LS1=5.7L, LS2=6.0l, LS3=6.2L, LS7 = 7.0L... and so on..
so. it really comes down to what you want ?... if your going FI.. an Iron block will give you more insurance due to the added pressure.. but the weight added is about 80+ lbs.. you can go with an LQ4 or LQ9 for a 6.0L iron block.
As far as the LS series, it comes down to Displacement.. more it better as far as being able to make more with less.. Torque is easier to make iwth the larger engines also.
BC
