07 LS2 into a 70 Chevelle
I'm new to this forum.
The next project I'm planning is a LS2 swap from a 07 vette into a 70 Chevelle.
What I got from the breakers is the engine with all the accesories the wiring loom ECM throtle pedal with controller, automatic transmission, as the vendor is saying everything included to get the engine running.
What I would like to find out is if I need a new wiring loom and ECM or can I modify the loom myself.
I'm based in Belgium, so not that easy to send stuff to the States
to have converted.Thank you for your help and tips to get this job done.
Oliver
Jon
PSI
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
The guy at the breakers told me that there is no separate controller for the pedal as this is included in the ECM of the 07 Corvette.
Is this correct???
Also, is there a separate ECM for the transmission or is this included in 1 box.
The engine came original with a manual transmision.
Thanks for your help.
