Suggestions for Best In-Line Fuel Pump
Old Dec 27, 2012 | 07:20 PM
LS1-32Ford's Avatar
Default Suggestions for Best In-Line Fuel Pump
I've installed a 2001 Camaro LS1/4L60E in my 32 Ford 3 window coupe. I plumbed a return #6 AN fitting into the fuel tank sender base. I need suggestions on which external fuel pump to install in line near the tank. Can I use the Corvette filter/return line system with an external fuel pump? I know in-tank is the best but i didn't want to cut/weld on my existing aftermarket 32 tank that has been in use with a 350 SBC prior to installing the LS1. Ideally I would like to install a reasonable quite/dependable fuel pump. I read some good press on the Bosch...anyone have experience with this pump? Also I want to use #6 AN fittings with the fuel pump. Any suggestions on brand/model fuel pump/regulator would be appreciated!
Chuck
Charlotte, NC
Attached Thumbnails Suggestions for Best In-Line Fuel Pump-dsc03996.jpg   Suggestions for Best In-Line Fuel Pump-dsc03998.jpg
Old Dec 27, 2012 | 07:46 PM
1964SS's Avatar
I'm using a walbro 255 external fuel pump with the corvette filter/regulator and it's working like a charm.
Old Dec 28, 2012 | 06:36 AM
99VetteFRC's Avatar
I put an A1000 inline on the Chevelle. You may have problems with sucking air if the tank is not baffled properly.You may have to keep it pretty full of gas. I drilled 3 holes and welded a sump in the bottom of my Chevelle tank and the holes and the bottom of the tank act as a baffle. I used the big pump because of the turbos. Fuel system is one thing you should always overkill... Later upgrades may need more fuel.
Old Dec 28, 2012 | 07:50 AM
JIMB's Avatar
I've used the Bosch 044 pump on three LS swaps with great results. No failures.
Old Dec 28, 2012 | 08:45 AM
zukboi2004's Avatar
Airtex E8248 from Advanve Auto is the one I bought cause it was readily available at a local store n has a warranty, I havent used it yet but have read lots of good reviews on it.
Old Dec 28, 2012 | 11:29 AM
bczee's Avatar
+1 on the Walbro or if you have the cash or want overkill ..the Aeromotive 1000..
BC
Old Dec 28, 2012 | 11:30 AM
ls1nova71's Avatar
What brand is you aftermarket '32 gas tank? I have a 'Tanks' gas tank in my '33 and was able to modify the sender to mount the pump since the hole in the top of the tank was big enough for the pump to fit in. Just a thought.
Old Dec 28, 2012 | 11:49 AM
wildcamaro's Avatar
I checked and found walbro 255 selling for about $120 with install kit... Good deal
Old Dec 28, 2012 | 01:38 PM
Andy1's Avatar
JIMB,
Do you have the specs on the Bosch 044? Pressure and volume? Also, what is a good source to buy one?
During my build, I had a new Walbro 255 that lasted maybe 30 minutes. I replaced it with another, but now I'm a bit skeptical since others have expressed some disappointment with its durability.
I know the Bosch inline pumps are very durable; Porsche used them for years.
Andy1
Old Dec 28, 2012 | 04:08 PM
reedld's Avatar
Chuck
Charlotte, NC
I'm using a Bosch 044 plumbed similar to the second post pics...I do not like the noise, so I am going to mod a new 2nd gen tank with a 4th gen fbody pump..via a vetteworks adapter.
Off topic...what air intake tube is that? Id like to possible do something like to incorporate my shaker. Nice build!
Old Dec 28, 2012 | 04:21 PM
Carshopinc.com's Avatar
LS1TECH Sponsor
Make your car a lot safer and use the AFX snap on PTFE fuel line instead of
the leak prone adapter fittings..with conventional braided line It costs more but well worth the piece of mind..
OHHH And no fuel smell either ... give me a call for a deal ..
Tim
Old Dec 28, 2012 | 06:52 PM
74modified's Avatar
I agree, I think most have a 6 bolt flange.
If you do mount it external, and pull out of the top of the tank, try to make the pump lower than the bottom of the tank to keep a "siphon" action going as the pumps don’t pull very well.
