Recomendations???
Old Jan 7, 2013 | 12:35 PM
87lsttop's Avatar
Default Recomendations???
Looking for the optimal spot to drill and tap the oil pan for the turbo drain. Any input on where. I know when I drilled and tapped my old ford pan for the vortech it was like 3 inches from the front and maybe 1 inch down from the bottom of the rail. That was on a moroso deep sump pan under a 302. Now I am using a stock 5.3l truck oil pan? Also looking for a place for the stock fox oil pressure sending unit. Thanks
Old Jan 7, 2013 | 06:19 PM
oldgoat69's Avatar
Same idea here. Needs to above the oil level line and hopefully opposite the windage side, so plan on the driver side, sheltered by the windage tray if possible.
