assecory brackets
Old Jan 19, 2013 | 11:55 PM
lowrolr's Avatar
Default assecory brackets
Dropping 5.3 in my 01 blazer. And im needing advice on which accesory brackets to use that will cause as little as possible clearence issues. This is my first ls build in the s series trucks. So any help will be greatly appreciated . Have gotten advice from ppl that have read about it but im looking for a tried and true method on the set up. Thanks
Old Jan 20, 2013 | 08:16 AM
10droped's Avatar
The vette acc. Will give you the most clearance. People have used the truck ones you have to change the power steering pully to a smaller one though. I'm using the kwik performance set with the fbody acc., the only real problem if u would call that is the fbody water pump sticks out and can make it tight between the fans.
Old Jan 20, 2013 | 09:18 AM
psiconversion's Avatar
LS1Tech Sponsor
We are now selling aftermarket accessory kits for $249. PM or call us to discuss.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
