Foxbody Wiring help
Old Jan 27, 2013 | 12:34 PM
damon0346's Avatar
Default Foxbody Wiring help
I bought a roller mustang and im putting an ls motor in and the wiring harness was taking out. I need help putting it back in. Does anyone know what wires I can take out and a pictures of the wires to keep. Thanks
Old Jan 27, 2013 | 12:51 PM
BP Automotive's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
the ls engine harness or the fox body harness?
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
Old Jan 27, 2013 | 01:45 PM
damon0346's Avatar
Foxbody harness
Old Jan 28, 2013 | 07:51 AM
damon0346's Avatar
Anyone?
Old Jan 28, 2013 | 04:35 PM
TopNotchLSX's Avatar
I was in the same situation with my harness. You may just want to keep all the plugs to keep the harness intact or else it quickly gets out of hand trying to simplify it. In my opinion it is not worth trying to strip down a factory harness because you will still have a factory old brittle bunch of wires. Just my 2c...
Old Jan 28, 2013 | 08:06 PM
87lsttop's Avatar
which harness was taken out? The engine harness or the body harness under the dash? If its the engine harness you dont need any of it except the oil and temp sender wires for the gauges if you are going to be using stock gauges.
Old Jan 29, 2013 | 06:37 AM
damon0346's Avatar
Yeah I think that's what I'm going to do thanks
