Wireing Harness ?
Old Feb 14, 2013 | 08:28 PM
Wildside's Avatar
Default Wireing Harness ?
Hey guys doing 69 firebird Ls swap for a Customer would y'all do stock wireing Harness and send it some were I have done that work out good and it come with a fuse box. Are do after market
Old Feb 14, 2013 | 09:36 PM
BOXCHEV's Avatar
Lost me
Old Feb 15, 2013 | 12:39 PM
mrhtl's Avatar
Do some searching on here, as there are a ton of aftermarket or custom built standalone harnesses ready to buy.
Old Feb 15, 2013 | 01:10 PM
bczee's Avatar
If you have the skills and can read both pin out and wiring Diagrams.. you can DIY it. many have. But if you have the Cash, no time and don't want to take it on, Then yes.. send it out. .mamy company on that will do it.
I am sure the usual Sponsor will ping in soon..
A new Custom Harness wlll usually look better as it lays out. You can get a Stock OEM one to look good, but it take some time to take it apart and put it back together to layout looking good.
if you are going to take it on yourself.. many on ths forum will be able to answer you quetions.
either way.. good luck
BC
Old Feb 15, 2013 | 01:12 PM
gagliano7's Avatar
I would go with PSI conversion.It will be worth the cost and it will be all new wiring.You could probably sell your harness to get some money back.It will save you alot of time and aggravation.
Old Feb 15, 2013 | 01:24 PM
BP Automotive's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I can make you exactly what you need or rewire your harness no problem.
On thing to remember is if you use a factory harness you are stuck to the factory length. Plus its hard to make a factory harness look as good as a new one.
One thing to look for and to think about when you are looking for a harness is what is included if needed
Fan Relays and wiring?
A/C relays and wiring?
Starter Relay and wiring? (Very good to have for clutch or neutral safety switch.)
Fuel Pump relay WITH WIRING.
In the end you should look around and see what is with the harness when you purchase it. There are companys out there who will sell a new harness for $350, but they use repair tooling to manufacture a harness ( big NO NO) or they are bare bones with no relays or sometimes no O2 wiring. Some use their own color codes and not GM color codes.
You get what you pay for. Pay now or pay later. There is no way around it.
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
Old Feb 15, 2013 | 09:46 PM
psiconversion's Avatar
LS1Tech Sponsor
What are the engine and transmission from? Are you putting AC in the car, if so what kind (eg vintage air)?
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
