84c10 5.3/4l60e
Old Feb 16, 2013 | 07:01 PM
84hernandezc10's Avatar
Ok Thanx. Can't wait to get back to town but won't be back til Wednesday. I heard some parts came in and an anxious to get started.
Old Feb 17, 2013 | 08:50 PM
Needing a cooling fan think this might work?? http://m.summitracing.com/parts/sum-g4904. Was looking for the fbody fans or even the truck fans but can't find any in the area. Can't find a blazer/burb speedo either.
Old Feb 18, 2013 | 05:51 AM
sweetk30's Avatar
few simple mods the ford windstar duel fan/shroud setup goes right on the chevy truck radiator size.
lots of guys have used them . 1 i read of was in the desert with built 454 bbc and never overheated.
Old Feb 18, 2013 | 08:43 AM
Ok cool ill have to check those out maybe I can find a set.
Old Feb 18, 2013 | 05:11 PM
sweetk30's Avatar
give me a few days i can take pics and show you how close thay fit.
i got a set and my rad shipped today from summit .
Old Feb 18, 2013 | 09:56 PM
Ok Thanx. What are you doing about power steering lines
Old Feb 19, 2013 | 05:50 AM
sweetk30's Avatar
both box and pump are metric so thay should thread right up to each other as if it never new the diffrence.
havent got to mine yet tho.
Old Feb 19, 2013 | 10:13 AM
Will be getting back to town tomorrow so ill will try and pull the motor motor before work
Old Feb 20, 2013 | 07:43 PM
Well this weather didn't let me pull the motor. But there was a lot of parts when I got home. What fitting to use off of the fuel sender?? Do I need to cut the ends off and use a compression fitting to -AN fitting??
Old Feb 21, 2013 | 05:19 PM
sweetk30's Avatar
as i said pics .
windstar fan setup as it was pulled. few cuts / notches and 2 holes for tranny cooler lines she be on and cooling .
few of rad .
few of fan setup on it .
and last was 4 core radiator isolators to fit the best to let it bolt in place. dont forget tho the upper mount brackets are specific to 4 core tho .
Attached Thumbnails 84c10 5.3/4l60e-0220131947a.jpg   84c10 5.3/4l60e-0220131948a.jpg   84c10 5.3/4l60e-0220131948b.jpg   84c10 5.3/4l60e-0220131948c.jpg   84c10 5.3/4l60e-0221131723a.jpg
84c10 5.3/4l60e-0221131723b.jpg   84c10 5.3/4l60e-0221131723c.jpg   84c10 5.3/4l60e-0221131723d.jpg   84c10 5.3/4l60e-0221131723e.jpg   84c10 5.3/4l60e-0220131953a.jpg
Old Feb 22, 2013 | 09:39 PM
Looks good what are you doing to mount them to the radiator?? I might have found a set of fans on eBay.
Old Feb 23, 2013 | 05:59 PM
  #32
sweetk30's Avatar
few simple tabs bolted to modifyed fan setup and bolted on just like the orignal shroud would have been on . 2 bolts 1 per upper rad clamp/mount . then 2 bolts 1 per side to the core support.
will space off just a tiny bit to make room for flex and if need be will do a seal around it .
Old Feb 25, 2013 | 10:54 PM
  #33
Got the motor pulled and new motor painted. Still working on the harness. Not letting me post up my pics but I uploaded some to my album
Old Mar 1, 2013 | 09:04 AM
  #34
Couple pics
Attached Thumbnails 84c10 5.3/4l60e-image_zps226af43e.jpg   84c10 5.3/4l60e-image_zpsd36f015e.jpg   84c10 5.3/4l60e-image_zpse5febe28.jpg
Old Mar 1, 2013 | 09:10 AM
  #35
More pics
Attached Thumbnails 84c10 5.3/4l60e-image_zps46bd8e2d.jpg   84c10 5.3/4l60e-image_zpsdcf12d2c.jpg   84c10 5.3/4l60e-image_zps94213ba6.jpg
Old Mar 1, 2013 | 06:57 PM
  #36
sweetk30's Avatar
oh those p.o.s dirty dingo mounts .
had my run in with him in the past .
lookin good sofar tho on progress.
Old Mar 1, 2013 | 10:23 PM
  #37
Haha yea I remember you said you didn't like them. When I got mine in the welds looked good and I also took them to a welder at our refinery and he said they were good. Hoping to get the motor in this week sometime. My girls came down for the weekend cuz it's my daughters bday and I needa spend time with them so we will see how much I can get done to the truck.
Old Mar 4, 2013 | 12:45 AM
  #38
Pics of wiring. Still have a lot of wires I need to route. Waiting for PCM so I know where to mount it.
Attached Thumbnails 84c10 5.3/4l60e-image_zpsafc1718b.jpg   84c10 5.3/4l60e-image_zps7ee5c240.jpg   84c10 5.3/4l60e-image_zps14867779.jpg
Old Mar 20, 2013 | 11:21 PM
  #39
She's running. Still need to finish the exhaust and either find a way to mount the air box or buy a cone filter. And mount the pedal.
Old Mar 20, 2013 | 11:42 PM
  #40
I'm not real sure where to tie the tcc brake switch in either
