'bout a '92 Dodge Stealth ES ?
Plus the car comes on factory 16x8" wheels and easily fits 245/50R16 drag radials at all 4 corners.
Best of all, I got the car with no rust, no crash damage, and a clear title for $300.
I'm thinking a 5.3 to make a start.
You hit on the exact point I'm stuck on. Do I use the twin turbo 3.0's 5-speed and transfer case and front axles, or do I turn the engine 90* and borrow an Astro AWD TC like the Syclone / Typhoon, with custom axles and custom rear driveshaft? Which gives mis-matched diff gearing front-to-rear.
But the rear 8.8 from a Mustang Cobra offers me 3.08:1 or 3.73:1 gearing I can get for a Syclone-style 7.25" front diff, which has the option of a low-cost Lock-Right, or the stronger 8.25" from a K1500, but I can't find any traction diffs for that. The K3500s 9.25' front had lots of diffs, but I don't need that monster even if it does fit, and it has no 3.08:1 gears that I can find.
So I can have a way-overgeared engine swap, or I can gave a decent-MPG drivetrain swap.
Whatever happens, I need to get the ruined V6 out of the engine bay this weekend. Then I can measure to see which might fit easier.
If you're up to the task, a full drivetrain swap would be much cooler. And it would be RWD biased, rather than FWD biased.
To me there's some temptation to try for a solid 8.8" axle, especially since the cost of 31-spline axles with a 5-on 4.5" lug pattern is so cheap. That's the lug pattern of these wheels. But since I owned and drove my old '85 300ZX, my first IRS car, I don't want a solid axle if IRS is practical.
I did some spreadsheets, and for a non-turbo 4.8L I like a 4L60E with 3.73:1, but for a ported, cammed, and turbocharged build I like a 4L80E with 3.08:1
I'm thinking run it non-turbo and RWD while gathering everything else.
No, I wasn't clear enough. I have no problem with the IRS from a TT AWD Stealth / 3000GT, but I'd swap the Mitsu rear diff for a Ford 8.8" diff for the 3.08:1 rear gearing, then need hybrid halfshafts. Same problem with the Chevy Astro 7.25" 3.08:1 front diff. need custom axles to connect that to my Mitsu-splined hubs.
The Cobra 8.8 was aluminum-housed, where the T-Bird version it's based on was iron-housed. Plus there are more designs of diffs for the ford 8.8 than for any import, and every one of the 8.8 diffs that isn't driver-selectable is better priced for what you get than any of the import options. I'm leaning toward an Auburn or a Lock-Right, or maybe trying a TrueTrac.
This afternoon I start on removing the V6, so pics tonight or tomorrow morning.
Who makes the Mitsubishi diff? The Subaru rears are R180s if I remember correctly. Maybe the Mitsubishi unit is also an R180? Pretty sure they came in the older Datsuns as well. That might open up more gearing options for the factory unit.
