Wiring harness help!
Old Feb 21, 2013 | 11:02 PM
Blackpony's Avatar
Default Wiring harness help!
I have a couple wires i am not sure what they go to, needing to know if I can delete them.
First one is on the green connector, pin 59 Crank volt its a purple wire.
next is on the blue connector, pin 39 relay control its a yellow/black wire.
Also what do these two connectors go to and can I remove them?
Almost done with modifying the harness. Never again will I do this!! What a pita.. haha
Here is what it looks like now..
Thanks
Old Feb 21, 2013 | 11:19 PM
gMAG's Avatar
What year is this harness?
I had to laugh with your comment about the pita procedure.
I paid someone to do mine.
Old Feb 21, 2013 | 11:30 PM
Blackpony's Avatar
It is from a truck, i believe 04 ish. I have been using a diagram for an 06 and thus far it matches up. Just confused on these couple wires.
Also where can I get pins and the tools to remove pins from the ecm connector? I cut a couple wires that i shouldnt have, now i need to add them back.
Old Feb 22, 2013 | 12:21 AM
i r teh noobz's Avatar
According to lt1swap.com, both wires listed aren't needed.
http://lt1swap.com/2004vortec_pcm.htm
Old Feb 22, 2013 | 02:17 PM
Blackpony's Avatar
Awsome Thank you!!!
