Tach problems
Old Mar 9, 2013 | 06:07 PM
alaninin's Avatar
Default Tach problems
I am having issues with my tach not working. I have checked and everything is connected right but it does not work. Is there a way to check the wire coming from the computer???
Old Mar 9, 2013 | 06:25 PM
rotor vs. piston's Avatar
Do you have your pull-up resistor wired?
https://ls1tech.com/forums/conversio...-resistor.html
Old Mar 10, 2013 | 08:42 AM
alaninin's Avatar
No, I did not now anything about a pull up resistor. I will try to figure this out but I am not sure where to connect the resistor. Before the shotgun shell that has all the wires coming from it or after right before the tach. My tach instructions are below. The tach is a ShiftWorks tach.
4. Your Tachometer will work with 8, 6 or 4 cylinders. It is preset for 8
cylinders. If you have a 6 cylinder cut one of the looped wires. If you
have a 4 cylinder cut both looped wires.
5. Your Tachometer is designed to use the factory lighting already
existing in your dash. Note: Now is a good time to replace your old
dash bulbs.
6. The Brains of your Tachometer are located in the Red Shotgun Shell.
There are (3) three wires exiting it:
Red Wire
Black Wire Green Wire
12V Ignition Switch (Fused Ignition port on Fuse Panel)
Ground
Negative side of the Coil (or Tach Terminal on Electronic Ignitions)
Zero Set: The Tachometer will point to Zero with the ignition on and the motor not running. You can check the setting prior to installation. The Tachometer will not return to zero when the engine is turned off.
Cautions:
1. Disconnect the battery during the installation.
2. Read the instructions and follow the diagram.
3. Connections need to be clean and tight.
4. Tachometer requires a minimum of 10 volts. Voltage must be
steady.
5. Check pointer prior to installation to make sure it does not hit screw heads on face of Tach.
3/4/2010
Old Mar 10, 2013 | 09:34 AM
ls1nova71's Avatar
You would put the pull up resistor between the ignition wire you're powering the tach with, and the tach output wire coming out of the PCM. Would be before your bullet thing. Also needs to be set to 4 cylinder mode.
Old Mar 11, 2013 | 08:03 PM
alaninin's Avatar
Thanks ls1nova71 and rotor vs. The pull-up resistor did the trick. The tach is now working. Who would have knew that all I needed was one 50 cent resistor.
Old Mar 12, 2013 | 05:09 AM
Goldhawg's Avatar
What computer are you using? I'm still struggling to get my E38 ECM to drive my tach even w/the resister.
Old Mar 12, 2013 | 05:20 AM
alaninin's Avatar
I am using one out of a 04 GTO. It has the long green and blue connectors that go to it. I think it is the same as the 02 Camaro but not sure.
