66 nova stock front end ls1
the motor. Its a 2001 corvette LS1.
stock bottom end
stock heads other then ls6 springs and push rods for the cam
edelbrock 2216 cam
edelbrock carb intake
msd 6010 ignition
and now for the fun part. PICTURES!!
how I got the car was a ****ty single stage "marina blue" haha A friend of mine painted it in his garage "cyber grey.
this is how I got the motor
northern auto re ring kit
LS6 springs and pushrods
the blue ones, not the yellow ones
got my GTO oil pan and everything I need for that, windage tray, pick up tube, and dip stick
Also got my adapter motor mount plates
got some car coils, but I also have a get of truck coils I have to clean up that I will use eventually.
got a set of edelbrock shorty headers for 30 bucks, so I will see if I can use them but if not I also have a set of truck manifolds. if all else fails Im going to go with the CBR mid length.
some msd wires also came with my coils...
got a mini hi torque starter from KMJ
Got my belt set up all done.
this is the belt and the ribbed idler pulley I used. it all fit perfect with the F-body low mount alternator bracket, idler pulley and bracket, balancer, and 98 camaro alt.
The dayco idler pulley was hitting the bracket a little so I used a washer that I had to modify a little to space it forward just a little to fit. works great. belt length couldnt be better.
just re painted my coil brackets
I made a little bracket for my MAP sensor to bolt to the carb stud
finally got my intake and msd
not using this carb but wants to set something on top to see what it looked like! haha
Cooling is really big for me so im going with the 4 corner steam tube. Also painted textures metallic haha
champion radiator
here is what my engine bay looks like now.
first off, when I first bought it
as it is now other than it does have headers now.
I have my torque converter and flywheel set up but I have to take some pictures. Ill get all that info and post some more soon.
I am dynoing my car as it sits on saturday and then doing it again after. Ill get some video and pictures of that.
as for the exhaust, i hear the gto manifolds are what work. but we will see. i have a set of truck manifolds and shorty headers. The plan is to actually do a twin turbo set up eventually when I can afford it so im trying not to spend to much on the exhaust. I really dont want to buy headers because they are expensive and I probably wont use them long. So ill make something work. or I might be doing a turbo set up earlier than I thought...
finally got some pictures to share. my fuel pump and fuel line is mounted and ran to the front. Just waiting on a fuse block that I should have thursday to start re wiring the old with the new and clean up some mess under that dash. got a painless 7 circuit and 2 relay fuse block to replace the stock one. now for some pictures. nothing to exciting but its something to look at.
cant decide which air cleaner... thoughts? haha
this is project fuel pump mount over kill
that is rubber in between the bolts, its actually the rubber deflector for the top of a snow plow. its thick and stuff but should still help with noise and vibration.
I forgot to get a picture of inside the trunk but there is another plate same size in the trunk. there is also another piece of the snow plow rubber in between the bottom of the floor and the bracket, and the thin rubber that came with the fuel pump between the pump and the bracket. all bolted together its super stiff but should definitely help with the noise and vibrations of the pump.
I used 2 wire insulated wire for my power and ground and run it through the grommet for the fuel sending unit into the trunk then up front. I will wire it once I get my fuse block.
cant even really see it. And I can actually adjust it up a little more.
oh and I got this in awhile ago to for my coolant hoses.
also my b&m holeshot 2400 and flat 6.0 flywheel with gm spacer and bolts.
once I get the motor in I will get a lot of the small stuff done, I just dont want to rush into it and have to re- do some stuff. but I had to get a new wheel for my engine hoist so thats why ive been held up for a bit haha. but I got it today so maybe this weekend ill pull the old motor and get the fuse block wiring done. and possibly set the ls1 in for test fit. Im short handed this weekend with my dad going out of town but Ill get it done.
now for some more pictures!!
plenty of room for alternator and oil pan!
you can see here how much further forward the trans is, about an inch from where it should be.
now just to figure out if I should use this air cleaner
or this one
